- February 13, 1999
- Location
- Tampa, FL
- Chief GPS'um and Still Lost Native Texan
- '99 EB 4x4 "Herc" RIP
I am positive my answer is already on this site but I got so many hits in search I cannot narrow it down to find it. Here's what happened:
The last time I switched from "4auto" to "4 low" I did not hear the transfer case clunk into low like I always hear. However after going a few feet it was obvious that it did since I was then in low. I switched to lower my huge boat down a ramp. After spending last weekend on the water we loaded the boat back on the trailer and I noticed that my dash indicator light was not showing that I was in 4low. As I pulled up the ramp, I noticed that my 4wd did not engage my front axle and I was only pulling with the rear axle. Upon leaving the launch area to drive home, the Explorer stayed in 4 low gearing and 2 wheel drive. As I was flipping the 4auto switch back and forth trying to get something to happen, it would sometimes light up that it was in 4 high but never light 4low no matter the position, and sometimes it wouldn't light any indication at all. I had to unbolt the shift motor off the transfer case and use a pair of pliers to manually turn the 4405 transfer case into high range to get home. It never engaged the front axle and went into 4wd at anytime during this.
My understanding is that powering the engagement of the 4wd is separate from that of high/low range shift motor, so I have two problems involving the same wire loom. The brown wire is obviously not sending power to engage the front axle, and at the same time the other wires that are suppose to be sending power to the shift motor bolted to the side of the transfer case are also dead. I was hoping for a blown fuse somewhere but could not find one. I'm not sure if any of the wires going into the side of the transfer case are receiving power. Whatever module it is that the 4auto/4high/4low switch on the dash controls may be toast, or what?
Ideas? Or point me to a thread that already has my answer, since I'm sure there's one in here somewhere
Thanks!
Thanks!
