DsrtExplorer
- December 4, 2008
- Ridgecrest, CA
- 91 XLT
I just picked up a 91 Explorer 4dr/4WD with only 89K dealer serviced miles from my neighbor who is pretty old and didn't drive it much. I had a '91 that I sold a few years ago and when he mentioned this one was going up for sale I jumped on it. Its in good shape and everything seems to work, exept the stock AM/FM/Cass (that would go working or not!). While going thru it, I noticed the front brake hoses were cracking so I replaced them and decided to change out the brake fluid while at it. Using my Mighty Vac pump, the fronts bled normally, but I am not getting any fluid from the rears. I tried each side, then put a "T" in the line and tried both at once. When I pump, vacuum builds, but no fluid comes out. I am wondering if the rears are even actuating when I apply the brakes. The pedal is firm and the vehicle stops smoothly without a pull so the fronts at least are working fine. I did a search and the only comments I found say with the RABS, the system can be bled normally, but maybe I need to try with a helper and push on the brake pedal and see what happens. Any suggestions would be helpful. Thanks in advance for any help.
Ken
New (to me) 1991 Explorer
Ken
