Brake Fade | Ford Explorer Forums
Brake Fade
polnudsky
Texas
2003 Mazda B3000
:us:2003 Mazda B3000 135000 miles
I hear a loud Clunk from the front end and then the brakes began to fade just before the roll stops. This doesn't occur every stop but is becoming more frequent. I suspect wheel sensors but I have never got an ABS light. Any help will be appreciated.
Sounds like an excellent suggestion. Thank you for your help and the link.
Regarding your "clunk". Inspect EVERYTHING while you have the front suspension unloaded with the wheels off
the ground. Usual suspects include lower and upper ball joints, sway bar end links and frame bushings, upper and
lower control arms, shock mounts, etc.
