Brake fade | Ford Explorer Forums
Brake fade
motorboy
Waukegan, Il.
2008 Explorer Sport Trac
Recently having the brake pedal get soft and having much longer stopping distances. My guess is, master cylinder?
Could very well be the master cylinder, but I would check all four corners, and the brake lines for leaks just in case.
If it isn't components like a hose or master cylinder, replace the brake fluid and bleed all 4 wheels. You need to flush all of the old stuff out as it gets contaminated with dirt/rust/water and loses its ability to hold pressure. I replaced all my pads & rotors and had no increase in performance until I did this.
