Brake light keeps coming on in my dash, then dissapears? | Ford Explorer Forums
1_v8_merc
calvert,MD
04 Mounty
Well basically the light keeps popping on in my dashboard, then dissapears......it seems to MAINLY do this when im off-roading....hitting potholes or bumps.
but it ALSO occasionally pops up REALLY FAST then goes away when im driving at high speeds on the highway.
I did a google search, and supposedely the light only triggers on a few things.
1.) low brake fluid
2.) un-even hydraulic fluid in the lines.
I checked my brake fluid, its FULL.
So this is probably just a Glitch right?
Im guessing it's just the TEMPORARY hydraulic pressure or fluid thats triggering the light whenever i hit a big bump or pot hole.....
Anybody had this before?
The light looks like this.........(! BRAKE !)..........or similar to that.
This happens to me sometimes, but rarely though.
I think that my e-brake sensor is just phasing out some times. It think my ebrake is pushed down when it is not.
I dont worry about it.
i had this same problem in my 99. for me it was the fluid was low then when changing the brakes in the rear i noticed the cable was snapped on the right side. once i filled the fluid up it stopped coming on. plus after replacing the snapped cable everything went back to normal.
I had the same issue but mine was saying low brake fluid on the display and it happened lot. I just couldnt take it anymore, and I knew that I had brake fluid. It ended up being a sensor right after the master cylinder was faulty, replaced it and called it a day. Havent seen that stupid light on since. (more than a year)
Thanks guys.
Yea im 99% sure its just a sensor or just a glitch.
Thats what i hate about newer vehicles....too many damn sensors!
(i had the same problem with my s-10 ZR2....whenever i took it off-road i would get ABS lights and emissions lights flickering and stuff,lol.)
I take my SUV thru water/mud sand and snow alot, so its probably just a sensor problem.
my brake light stays on all the time im pretty sure that its a sensor issue for both of us
