Brake lights & flasher problems. | Ford Explorer Forums
knkpatrick
Santa Clarita, CA
Explorer 94 XLT
I have two problems that might not be related. All the Brake Lights went out on my 94 explorer, due to the great advise on this site, I replaced the Brake Light switch and everything was great. I was just told all my lights are out again, it has not even been a month. I replaced the Brake Light switch a second time, and it did not fix the problem. Also my blinkers flash at irregular beats. It will flash steady for a couple of minutes then they start to slow down and speed up. Any ideas? Could the problems be related?
Slowing or speeding blinking can be from a drop in voltage. When im listening to a song up loud, lets say at a light, with my blinker on, in drive, stopped, and its a constant heavy bassline, my voltage drops quite a bit, and the blinkers blinking speed drops probably by half, but as for the brake lights, did you check the fuses?
