brake line and extension question | Ford Explorer Forums
Xeek
Virginia Beach, VA
1991 xlt
ill try this in here, if it needs to be moved thats fine.
i just swapped a 99 rear end into my 91 with the help of jd.
the brake line on the 99 was cut where it goes to the framerail.
besides it being cut, it also needs 6-8" extension. the way to attaches to the junction itd need the drivers caliper line attached also. i have no idea how itd attach it otherwise.
and it needs to attach to the 91 framerail connector, if it happens to be different from a 99 or not.
ill get more pictures in a minute
99 rear brakes. the caliper is attached a different way, im guessing id have to buy it with the caliper line also.
and this is the type of connection it needs at the frame hard line. from the 91 axle
so does anyone know where to buy a line from?
