stangsteeda
- February 17, 2009
- Asheville, NC
- 01 Explorer Sport
Hi guys, I have a 2001 Sport 2wd with manual transmission. I just finished a Springtech 3" spindle lift and discovered my brake pedal goes to the floor only occasionally. When this happens they can usually be regained by pumping the pedal.
To accomplish the lift I replaced the factory 12" rotors with new 11.25" rotors and reused the stock calipers and pads so no bleeder screws or lines were opened. When I unbolted the bracket holding the hard line from the frame rail I carefully secured it lower and wrapped vacuum tubing over the part of the hard line where it contacts the frame rail. I have jacked the vehicle up and looked to ensure the brake lines are not overstretched or pinched and they look fine. Also the fluid level looks good, the ABS light is not on, and there are no leaks that I can see. This also is not really a problem that occurs under full lock steering as some people have experienced it happens at any steering position.
Thanks, in advance.
Thanks, in advance.
