Brake Pedal Lubrication | Ford Explorer Forums
willied
Columbus, GA
2006 XLT V8
My brake pedal squeaks a little bit when I push it down, and I was wondering what type of lube to use?
Naw. That's not real lubricant.
white litium grease. 3 in one, graphite, KY
wont matter which you try they will all dissipate and the squeak will be back
on a side note i had a strange break pedal squeak on an explorer a few times, it was the booster pin where it contacted the master cyl.
Might want to check your brake fluid. I had the same problem, expecially when X engine compartment was warm/hot. (Typically after driving a while during summer months.) After changing the brake fluid my pedal is smooth again.
It seems that after the brake fluid ages it no longer is a good lubricant for the master cylinder.
Thanks for the suggestion. I'll get that checked out.
is there a way to tell if your brake fluid is bad?
