Wondercookie
- November 29, 2012
- Warm Springs, OR
- 1991 Ford Explorer
1991 Ford Explorer
4.0L
4-door
4WD
V6
Recently, my little brother was driving when his brake peddle suddenly went to the floor. There was a loud banging, he said, and to get the vehicle stopped he had to stand on the brake peddle with both feet.
I've replaced the brake booster and vacuum checking valve and hose. Upon test driving it afterwards, the brakes worked fine for one or two pumps, and then immediately went to the floor again.
The steering seems off suddenly, and can pull to either side. There is also a THUNK! from time to time.
When coming back from the test drive, I had to stand on the brake peddle with both feet to get the vehicle stopped.
Any ideas? Before this, the vehicle ran fine, he said. The Check Engine light came on just before his brakes went out. Is it something to do with the vacuum? Maybea leak? Thank you so much.
4.0L
4-door
4WD
V6
