Brake problem | Ford Explorer Forums
Brake problem
chrystal
essex uk
2000 North Face
New pads and discs,in a straight line it stops fine. however when braking as the steering wheel is turned the brakes at the front become juddery, like they haven't fully clamped the disc between the pads, any ideas?
With brakes I would not take any chances. You should check them soon. with the wheels off the ground, are the wheel bearings tight? calipers in place correctly? any parts worn? Stearing components in good condition? Was the problem present before the new brake parts?
Good luck, Jim
