mrfrogington
- October 27, 2003
- MA
- 99 XLT
Hi, this is my first post. I just switched over from a Wrangler... needless to say, I'm much happier so far.... I can hear myself think.
I have an 99 XLT 4.0 SOHC with auto AWD. I wanted to check my tires so i put it into neutral and jacked up the front passenger side tire. I wasn't able to spin the tire, almost as if the brakes were still on. I then jacked up both rear tires with it still in neutral and I couldn't get those tires to spin. Is this because of the awd and the transfer case or does it sound like I have a brake issue? I was told I might have a bad master cylinder or perhaps teh fluid needs to be flushed. The brakes work fine, in fact, i just had front rotors and pads put on.
Any advise would be appreciated, I'd hate to have more work done only to find out it's just the AWD, something I'm not used to.
