Brakes Need Help | Ford Explorer Forums
Brakes Need Help
hitman17mk
Southwick, MA
2002 Eddie Bauer
ok, i got a huge brake leak, it is the hydrolic control unit (the thin the master brake cylinder connects to) and one of the 3 silver things stickin out is lettin brake fluid out like a super soaker everytime i hit the brakes, and i was wonder howe this will cost cuase i doubt it can be fixed, or what i can do to gain more pressure till ig et it fixed, i use a epoxy and it got me a little pressur ebut not much, and i got 94 limited wit abs so i think it might cost a pretty penny, any help appreciated
thanks
mike
Where is the leak comming from? Is it the "silver things stickin out" aka brake line. Or is it actually comming from the "hydrolic control unit" aka ABS hydraulic control valve? If its coming from the line, you can replace it (but you will need to make a new one since prebent lines are not available). If its comming from the valve, the only fix is to replace the entire unit with a used (wrecking yard) or remanufactured unit.
