BRAKES | Ford Explorer Forums
BRAKES
kdogg212001
stockton, california
94 xlt
ok i have recently bled my brakes all the way around fluid otu f all my line everything looks good, but when i start my car i get only a little bit of pressure on the peddle, like i can push it down to stop but driving in the mountains i have to pump my brakes a little bit to ensure a stop, shouldn't the front disc lock up if i slamed on the brakes??
Yes if you slam on your brakes you should lock up....Mabey there is still air in the lines did you bleed both front and back?????
Your '94 has 4-wheel ABS, it shouldn't lock.
What is the condition of the pads and shoes? If they are good, sounds like the system isn't fully bled. Has the system been opened recently?
yea my pads are brand new
my mom's 94 will lock up then the abs kick's in
