Bronco II gas tank | Ford Explorer Forums
Bronco II gas tank
aiiraciing
OC
04 Ford Sport Trac
I'm hoping to find some info about running a Bronco II gas tank in my 04 Sport Trac. I know its pretty common with Ranger guys but I'm having trouble finding threads about it.
Here is the tank that I'm looking at, ( http://cgi.ebay.com/ebaymotors/NEW-...rQ5fTruckQ5fPartsQ5fAccessories#ht_2671wt_914 ) just not sure if its the right one and what will be needed to get it running. I'm pretty sure it is the correct one, and I believe all I have to do is drop my stock fuel pump in and move the lines over from the stock unit and I should be good to go. But I want to get info from other's that have done this swap or have looked into it.
Thanks, Brian
Hello Brian, that tank will require a pickup assembly like the Bronc II has, which is different from yours. I'm not sure how people deal with that, but keep hunting.
