429CJ-3X2
- November 6, 2009
- Des Moines, Iowa
- '01,'02, '04 Sport Tracs,
After driving all over the area Wed, I realized my '02 Sport Trac needs a fuel pump and filter ASAP. I started by pulling the fuse for the fuel pump and cranking the engine to relieve the pressure. Of course, there's roughly 12 gallons of gas in the tank. I can't get a siphon tube thru the filler hose, so I'm trying to pull the fill hose off the (plastic) tank. Tank is still in place in the truck. I cut the clamp off, and can twist the hose, but can't get it off the neck on the tank. There's quite a ridge there. Any tips or tricks to draining the tank would be appreciated.
