CommandPresence
- January 3, 2012
- Massachusetts
- 2018 Explorer XLT 3.5L NA
I am curious about a few things. I wired a switch, simply putting a single pole single throw switch in, rated for 10 amps, no relay. All I did was simply connect a switch between each end of broken brown wire, one wire on a terminal and one wire on other side of terminal on switch. I did not run power or ground because I did not use a lighted switch. It will now break loose in dirt in 2wd....
Question 1; If I want to go into 4x4, do I need to flip the switch and re start the vehicle, or is it on the fly? I flipped the switch while driving and didn't notice if it was still just 2wd.
Question 2; When I hit the 4 High button, the light still goes on on the dash as if it's in 4HI, is this normal because the computer thinks the t-case is engaging?
Question 3; my 4wd lights light up with all other lights on dash as i first start it, regardless of switch position, are they suppose to?
