Brown Wire mod idea | Ford Explorer Forums
Brown Wire mod idea
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
I've been pouring over the schematics today, and I have an idea about the brown wire mod. From what I gather from schematics for my '98, there are two brown wires that feed the coil on the transfer case: One comes from the TOD relay, and one comes from the Transfer Case Shift Relay and they meet at splice 249. If I'm looking at it correctly, and I put the switch in between the TOD relay and its junction with the brown wire from the TCS relay, I think shifting the truck into 4 hi should still allow the coil to engage the transfer case, no?
(i.e. can I still shift into 4 hi without remembering to flip the switch I installed back on?)
If that works, that's the way I want to wire her up. That should (finally after 7 years of annoying Control-Trac!!) give me 2wd, 4wd, and 4 low most of the time, and the switch will turn the Control Trac in 2wd mode.
For those of you that have done the mod, please mention EXACTLY where you cut the wire to splice in the switch.
Thanks, gang!
-Joe
Brown wire with a twist!
Well the proof is in the pudding... I did the brown wire mod today with my own twist. I broke the wire between the junction and the transfer case and wired in an SPDT on-off-on switch. The way I wired it up it should work for ALL Control-Trac Explorers, including the 95-96.
Like the original brown wire mod, it allows me to disconnect the front driveshaft at will, allowing me to alleviate the drivetrain bind-up without disengaging the 4wd. This is especially useful if you are in low range. (For high range, it's really no big deal as it was just a matter of flipping the switch)
For the 95-96 with 4 auto, it also allows you to force the control trac to stay engaged, giving you a full-time 4wd high.
Tried it out and it works like a charm. I'll post the pics in the morning. :)
-Joe
