Brrrrr. no heat but good fan | Ford Explorer Forums
JackSpackle
Utica, NY
2004 Explorer
2004 Explorer with no heat. Fan works fine on all speeds. Had problem with heater in the past where the fan only worked on 4 with heat. changed module under dash and it was corrected. Don't know if it is related??
Thank you
Probably a blend door actuator. Do you hear a clicking sound when you move the temp knob?
Also could be a clogged heater core.
This one should probably be moved to the gen3 section since it is a 2004.
talked to a guy from Autozone today. He felt the two hoses coming out of firewall and both were ice cold. said might be clogged. Mechanic said might be a valve that controls flow of water for heater unit?
Any thoughts. thank you for reply
