Bulb number for a 94 | Ford Explorer Forums
CrazyAlaskan
Wasilla, Alaska
1994 Explorer Limited 4wd
Ok this may sound like a stupid question but Im looking at buying some HIDs for my 94 Explorer Limited and I was wondering if any one could tell me or link me a website with this info. I think its 9004 but im not sure, and im looking at possibly getting some HIDs tomarrow. ANy info would be appreciated.
1994 FORD Explorer
High & low beam headlamp
9004
9004SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9004ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9004EB EcoBright - Your Environmental Choice
9004XV XtraVision Halogen - The Brighter Light
9004CB Cool Blue Halogen - The Whiter Light
Parking light
3157
3157ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
3157LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
3157
Rear turn signal
3157
Tail light
3157
Stop light
3157
High mount stop light
912
912LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H2
H3-55W
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3156
3156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Ash tray
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
906
906LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
168
906
912
Trunk/Cargo area
211-2
211-2LL Long Life Upgrade: Up to twice the life of the standard lamp
Under hood light
906
Instrument-general
161
1815
194
Check engine indicator
194
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Directional signal indicator
194
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Copied/pasted from:
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
thank you very much, I actually just found the same site (I think any way all the wording is the same) a few mins ago :D but thanks for posting any ways.
No porb. Good luck with the HID's
PLEASE DON'T get one of those crappy "HID" bulb kits.
The 9004 bulb may be sub-par compared to most others, and the stock headlights aren't that great, but that's not an excuse for resorting to illegal and DANGEROUS mods.
The crappy "HID" kits will just be crappy "HID" type bulbs (of a vastly inferior quality to real HID bulbs by quality manufacturers) that aren't even the right kind for the housing. Even though the "HID" bulbs may have a 9004 plastic base to fit in the stock housing, the bulb isn't designed to have the light where you need it, on the ground in front of the vehicle.
You can be certain the lights WILL be brighter, but at the expense of other motorists, who you will be blinding with your "HID" bulbs glaring straight into their eyes due how the bulb reflects on the stock reflector and how the light goes through the stock lens, which is made for a 9004 halogen bulb and only a 9004 halogen bulb.
If you want a safe (not to mention less expensive) solution to better lighting, get some Sylvania Xtra Vision 9004XV or Philips Hi-Visibility 9004 bulbs. Both bulbs are brighter than a normal 9004, and will put more light on the road without compromising the way the bulb works with the stock reflector and lens. If you just want the look of HID, consider Silverstars or some other blue or white bulbs by Sylvania or Philips.
