Chasethexplorer
- May 12, 2009
- Austin, Texas
- 99 Explorer Sport
99 Sohc 207,x.. miles. I have been noticing that I keep getting low on coolant for the last few months, but have not had any issues with overheating. The other day I noticed that right after I start my truck it was white smoking from the exhaust, just a little bit but then went away fairly quickly and is totally gone (no smoke) when engine is totally warm. The other night it was 40 degrees out and when I started the truck it was pouring white smoke out of the exhaust, i have my muffler cut off so I have dual pipes and it was coming from both sides. At first I was sure I had a cracked head or blown head gasket, so I bought some head gasket stop leak which I havn't put in yet, once I realized it was coming from both banks of cylinders that made me think of the possibility that both head gaskets going at the same time would be highly unlikely. I remember reading somewhere that a leaky intake gasket can leak coolant? So my question is could a leaky intake gasket be the culprit, would it be a lower intake gasket or is there only one. Also should I put that stop leak in anyways since I already bought it or would it be bad to add if the head gasket is fine. I feel pretty confident that its not the heads or head gaskets now because thats wierd that its coming from both sides. I am going to try to find a compression tester first as that would probably tell me if my head gaskets are good. Now I just read that the sohc intake gasket doesn't have any connection to coolant so Im really confused.
Thanks, Chase
Thanks, Chase
