djpanfire
- September 24, 2008
- Port-au-Prince
- 97 Xlt 4wd
I Had This Problem :
"Really don't know what to do
My explorer when cold will start normally it will go to 2k RPM and go back down progressively to 1 or 1.1. The problem occurs when you try to accelerate the RPm will drop and it will go into a bubbluly state. If you let it warm up a bit it wont do it but it's obvious that I have a loss of power (can hear the valve clacking when I give to much pedal) and it will sometimes hesitate when changing gear.
Changed:
IAC
FPR
Coil Pack
Spark Plugs
Fuel Filter
Fuel Pump
Check and clean injectors
Intake Lower and Upper gasket (did overhall)
Seems top me like it just not getting enough gas I don't know help anyone
PS: Was working really fine after the overhall was done. After that it took one week for me to feel and notice the power decreas. "
The Answer to All this was Changing the MAF Sensor
Well the problem is now its burning MAf sensors.I am caught in a cycle. I get to the point where it bubles cold and hesitate while accelarating. Puting in a new MAF sensors does the trick until it "burns" too. I tought it would be the EEc acting up but no got two of them now and it still crashes the MAF sensor at a certain point with either one of the EEC.
Changed:
IAC
FPR
Coil Pack
Spark Plugs
Fuel Filter
Fuel Pump
