bypass hoses? | Ford Explorer Forums
bypass hoses?
thooker
las cruces
none yet
Most of my experience with V8 fords shows that there is one bypass hose from the water pump up to the thermostat housing. My '96 explorer has two hoses: one that is like above, and one that connects to the intake manifold at the same place as the temp sensor, then heads over to the heater core.
I am removing the heater core plumbing from this motor: do I need to keep that second bypass hose? Do I need it?
Thanks!!!
Anyone? I now have an L 1/2" pipe fitting to reconnect it if needed...
