C1280 yaw sensor | Ford Explorer Forums
C1280 yaw sensor
Ted22
Virginia beach
05 explorer 4x4 6cyl
Hi, right wheel started pulsing while driving straight , now showing a c1280 code.
Can anyone recommend a scanner that can diagnose the ABS system, and calibrate after/if I replace any parts? Saw this one, but not sure if it will calibrate new parts:
http://mobile.walmart.com/ip/14644662
Thanks!!!
I use the same model/make that Autozone uses for their loaners and it works great for our vehicles. It is an Actron CP9580. You can typically find it on Amazon with the carrying case for a decent price.
Just replace Yaw sensor on my 2006 EB, got sensor from Rock Auto, Standard Motor Products sensor. Pain to replace unless you have small hands. Sensor is forward of the gear shift in the console. Small amount of dis assembly, but not bad. About $250.00 for sensor.
