J
jluv
I lowered my '04 XLS over a year ago with Belltech springs, and from settling/being worn in and with the extra weight from my system and whatnot the truck sits 3-4" below stock. It looks great! The problem is that my camber is WAY off all the way around. I paid over $200 a while back for an alignment and they really only fixed the toe in and adjusted the camber as much as they could. It has chewed up one set of 22" tires already, so when I get the new set I want to fix the alignment problem. I did a search and read through some other threads, and I see the Ingalls kit recommended. It doesn't sound like the Ingalls kit is going to adjust mine near enough though. Is there another kit? Can two or more kits be used together to get more adjustment? Any info, links, etc will be greatly appreciated.
