Can 03 rims fit on my 91? | Ford Explorer Forums
xmodster3o3
Ontario, Ca, USA
91 XL
I got a 91 X, and I saw some stock 16's off a 2003 X on ebay for really cheap, my question is will the 2003 rims fit on my 91. The auction claims they fit all years but I just want to make sure.
Yes, the offset on all Explorers is 5x4.5, any year will match another.
thanx for the info, hope i win them.
hmm.. i was thinking the 3rd gens stopped using the 5 on 4.5. that not the case?
they will fit
however.....
they will set slightly in from what your stock ones do. The offset/backspacing is slightly different than your stock '91's. you probably loose a 1/3" track width on each side
you will also have to drill a hole in the front center caps to clear the 4x4 hubs. The front caps also require a different lug nut to attach than what your '91 might have. fordpartsnetwork.com (a sponsor of this site) is a good source for getting the lugs if they are not included
I did it and have had no problems with it
let me know if you have any other questions about it.....
ahh.. maybe that's what i saw was different.. the backspacing. thanks for clearing that up.
Hmm.. I tried to put a set of 98 rims on my 92 and there was a ridge in the rim that wouldn't clear the center thing on the back drums.
