youonlylivetwic
- February 23, 2005
- Milwaukee WI
- '00 Sport
Hi, my left brake light works, and the right does not. I have checked and replaced the bulb, fuse, and found a thread about the MFS, but can't confirm if that is the problem. As a temporary fix, can I simply tap into the left brake light and run a wire to the right brake light? Would I need to temporarily disconnect the right light wires and hook up only the jumper from the left? Or can I tap the jumper from the left into the right side and leave the right side hooked up as well?
The right side light comes on, but it does not register when the brake is applied. thanks for any help!!
