- February 8, 1999
- 2006 Honda Accord
Originally posted by jonny 5
Is it possible to put the Warrior shackles on both ends of the spring to get 2.5 inches (1.25 x 2)?? Most likely a dumb question, but worth asking
You don't want to do that, because then your axle will be able to move side lateraly on you and pull the drive shaft out. It is not a safe thing to do.
One other point about shackles. ON most Explorers the stock length is 5.5". The Warrior shackles are 8.5"(eye to eye). Putting extended shackles on one end of your springs will only net you half the differance between the stock shackles and the extended shackles, therefore the differance between the 2 shackles is 3". That will net you a lift of 1.5".
