Can't get into Low1 | Ford Explorer Forums
Can't get into Low1
jay3253
Ames, IA
'00 XLT
2000 XLT 4.0SOHC
I can't get it into Low 1 All others work fine help.
1st gear, or 4 Low?
If 4 Low, are you putting the truck in neutral, foot on the brake while completely stopped, and then turning the switch to 4 Low?
When you say it won't go in, do you mean the trans won't move in 1, the gearshift/shift indicator on the dash won't go all the way to 1, or...
It will not go into first gear. I have done everything I can think of.
Does reverse work?
who uses low1? just kidding, check the linkage it does bind. mine did was having trouble shifting into reverse and it was just a linkage issue.
