Car won't start | Ford Explorer Forums
Car won't start
bmd107
Tulsa, OK
91 Exp Sport
Everytime I turn the key over it acts as if I have no life in my battery. I have had the battery and alternator tested and both are fine. What would cause my exp to do this. It is a 91 explorer sport. All positive help is needed. Thanks.
probably bad battery cables and/or connections.
I just replaced the negative last night and I started fine all day and then just a minute ago I went to start it and I get no power when I turn it over to start or when I turn it back to listen to the radio. Could my ignition switch have anything to do with this. If so is it hard to replace.
Check your Pos cable. They rot on the inside, especially on the First Gen Explorers
