If it's the type that is made for Explorers with the built in mounting holes. Older explorers didn't have the mounting holes and you had to install mounting brackets. The covers look exactly a like except for end where they mount. If it has plastic end caps with a square that comes off of the end and is a molded part of the end cap than it should work. The other type has a metal semi-triangular shaped cap on the end.
