catalytic converter | Ford Explorer Forums
catalytic converter
jim ashton
warren, michigan
96 sport
i want to know if there is a way to test or jump out the catalytic converter sensor. when i hook up to a diagnostic computer the reads cat. bad, but i want to make sure it's not a forty dollar sensor rather than a eight hundred dollar converter.
Is your truck over 50,000 miles?
Is your truck over 50,000 miles? If it is check out www.truckperformance.com They have a highflow cat that will replace both the front and rear for about 225 bucks. They also have seperate ones for just the front and rear. They are 60 & 80 bucks I think. If your over the 50k mile mark it would be a lot cheaper to go this way. Plus you'll get a bit of a performance gain.
Bryan
aka Jokeman
i would just buy the new sensors. if the light is still on, then buy the high performance cats. I replace the sensors on my truck every 75,000 normally
I am guessing that you have a pre-cat O2 sensor and an after-cat O2 sensor. It sounds as if your after-cat O2 sensor isn't seeing the results that it expects. That could either be because your cat is bad or your O2 sensor is bad. There are probably a couple of other reasons as well though. You can do an O2 sensor test and monitor the O2 sensors with the proper OBD-II tester. That would tell you if your O2 sensors are operating properly. If your after-cat sensor is locked up at some voltage then I would suspect your O2 sensor is bad. It should always be able to adjust its output somewhat based on the information it is receiving. If the cat is bad, I don't know what other symptoms it would exhibit besides being plugged up. If it is plugged up you can have an exhaust shop install a pressure gauge before and after the cat and determine the pressure drop across the cat. If it is too high, then your cat is plugged and needs to be replaced. As the previous post said if you need to purchase a new cat, a high-flow, aftermarket one would be much cheaper than going directly to Ford.
