center console removal | Ford Explorer Forums
LoKo498
J.C.,N.J.
2002 XLT
I have a question & I'm sure its posted somewhere but I have not found it.
I'm trying to remove my center console from my 02 explorer XLT.
Can someone guide me how this is done or provide a breakdown sheet on this.
Also I'm wondering if anyone has complete breakdown of the entire Explorer.
a hanes manual should help you do all of that for a cheap $20 price tag.
if you want an actualal break down repair book, youve gotta get a ford shop manual, but be prepared to spend several hundred id guess.
thats why i just stick to hanes and chilton. they give enough info for must projects.
I was actually hoping that someone on this forum would have that info up for grabs for us to use.
That's how I got all the info I needed when I used to have a neon. I joined a forum & we shared all the info & someone provided a total breakdown of the entire car.
But let me know if anyone knows the steps to remove the center console.
Thank you guys.
Here is what I have
Hope that helps You can find all this at Auto Zone At this link http://www.autozone.com/autozone/repairinfo/repairInfoLanding.jsp
I was looking on how to remove the center part between the 2 front seats, that console.
Thank you for the dash info tho!
Still no luck. If anyone can help me please, I have a 2002 Explorer XLT.
Thank you guys
It's pretty easy to remove the "Front Floor Console":
I believe that after you remove the 4 screws (bolts) from previous post you get into the back seat and push the console forward - not 100% sure but that is the way is is on 2nd gens
Thank you jhard for that breakdown sheet with that info.
Do you know where I can find a complete breakdown of the entire 02 Explorer? I checked that website thats posted on the sheet but cant find anything.
Thank you again for the help!
No problem Loko!
FordTruckin.com is just a little side project of mine. I've been so busy haven't had a chance to upload all the sheets and publish them, but if there's any specific area you need for now PM me with a request!
I had a chance to work on the console & the top part came off as the instructions said.
1 screw & I just had 2 pull hard for the clips to release.
Under that part is where the other screws are located.
