Centerforce Clutch | Page 2 | Ford Explorer Forums
Centerforce Clutch
i was just asking a simple question
Hey Peter I dont think the clutch will kill your tranny, its more likely the tires and gears your running that would kill it. You changed to larger tires, but have you changed the axle ratios to reflect the switch to larger tires, and the way you use the truck. The larger tires are doing more to "kill" your trans than the clutch will ever do.
From reading the posts the simple answer is the dual friction.
The long complicated drawn out answer is that the drivetrain is mismatched to the use.
Hey Bionc Marsh, when you ordered your clutch from Summitt racing what came with it? CLutch disk, to, ?
32s are not goin to affect my tranny more than a meaty clutch like that...i got the centerforce stage 1...guaranteed that will work fine, and the dual friction was a waste of money for my purposes.
its all over now...the centerforce stage 1 is in...perfect for my uses...thanks yall
