jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
for starters i have a 5.5 lift with James Duff radius arms and will be adding f-150 seats and a 3" body lift this week.my question is how do i center the front spindle or lower spring mount to the top one or should it be centered.my problem is that one wheel is not centered and sits off in the fender well.driver side looks close but my passenger side is off and the tire will rub when turning but the driver side wont,but that's not the under lying issue,the spindle/lower seat mount is not centered from what i can tell and sits farther back.so font post about trimming or that the fender my be mounted farther back or whatever.i would like to have it like an inch farther towards the bumper or front of the truck as i have more clearance up there.i take the first step would be take the tires and springs out and set the truck to where the center of the hub/spindle and upper spring mount is sitting at the level at witch the truck sits at ride height. this is where i get lost.im thinking that the truck or the upper spring seat needs to be level to do this.i would say to find the center of the top spring mount and run a bar or stick across it and hang a string weight from the center and let it drop down to the lower spring seat and adjust the axle by the jd arm hemi mounts to where the lower spring mount bolt is centered to the string weight from the top.that to me sound like it would center the lower spindle or spring mount in relation to the upper at ride height.the reason i may or would like it and inch forward is because i think the hub moves backwards as its under flex so it would center up or have a little more room in the fender well under flex.but center at ride height is where i need to start with.soo sound plausible,anyone have the real way or a better way?:scratch:
