changed idler pulley, still got the whine noises.. | Ford Explorer Forums
WannaXP8
St. Louis MO
1998 Explorer
I thought that my idler pulley was going bad, cause there is a whine coming from under the hood, and I cant tell what pulley its coming from, how can I tell what pulley its coming from?
maybe if you take off the supercharger you wouldn't have the problem :p . Sure it isn't the belt? Try to put a little oil on each pulley to see if it goes away. Do one at a time so you know what one it is.
Are you sure it's not the great Ford P/S whine?
LOL he would of probibly noticed that when he bought the truck brand new :p
have had the truck since new, its got 93000 miles on it now, and now I wish I would be able to take the supercharger off..no wait I would like that kinda whine..I dont really wanna take it to the shop..i hate shops..I like to do the work myself
There should be 2 idler pullies and one tensioner pulley. Could be any of the three. Not sure if the blower adds any more - I had to add one.
As for determining the location, if you are careful, you can put a metal rod to the pulley bolt and put to your ear. This is a good way to hurt yourself though, as the fan and belt are attracted to anything you put near them! Not recommended.
go to napa and get a stethescope to check where its REALLY coming from. could be the rear bearing on the alternator. pretty common to make noise. could be any of the pullies. I have even seen belts make noise although they look fine, no cracks, glaze, etc.
Whine
Been there, been driven batty by it. There is a service advisory on front inner axle seals.
The give away symtom was when the whine would temporarily go away after hitting a water puddle, or after washing the truck.:eek:
the belt will make a chirping sound, not a whine. I've been through 4 belts, none of them fixed the chirping sound during the winter when I start up.
Usually the whine is the PCV valve... especially if you hear it loudest at idle. There are a bizillion threads about cleaning it.. takes 15 minutes.
Edit: wasn't paying attention that you had a supercharger... no clue what to do to fix it =P
its not the inner axle seals, it does it when the truck is in park and just running, its not the pvc valve, its a bearing noise, and no I dont have a supercharger, wish I did, but I dont. But thanks for inquiring on my post.
When I had a wine it was the idler pulley, the pulley way at the bottom. Sorry, I don't really have an answer for you. Do like they said above and spray some lube on each pulley to see if you can pinpoint the prob.
My bet is on the PCV or IAC leaking a little. Is the idle a little rough? I would just unplug the hose connecting your PCV to the intake and plug it off with something and see if it goes away.
its not a whistling like air, but a bearing noise...
one thing that I saw someone do to hear something in an engine... get a long screwdriver, put it next to the thing holding the bearing, put your ear on the screwdriver... I dont know if this will help, just an idea.
