Changing the time on stock unit. | Ford Explorer Forums
Mr. Logger
Benbrook, TX
'99 Mountaineer
I have the stock head unit still, and was curious as to how you change the time... It's the one with CD and tape deck. All I see is a CLK button, but all that does is display the time. I've tried holding it down to see if that's going to help, but to no avail. How do I change the time? Thanks for your help in advance! Ciao
Best bet is to check the owners manual. I have a 94, which has a separate manual for the radio, not sure if that's still true in 99.
On the 94, you have to press and hold the clock button, and press the up or down tuning buttons at the same time to change the time. Maybe that's still true on the 99? If that doesn't work, hold the clock button and press one of the volume buttons. If that doesn't work, hold the clock button and try any of the other buttons.
Hope this helps. Let us know how you make out.
Mike
That worked Mike. Thanks!! I only wrote on here, as whoever had the Mounty before me lost the owner's manual. Thanks again for the help. Ciao
