How to set the time on sohc 4.0L v6 | Ford Explorer Forums - Serious Explorations
PirataBoricua
1999 XLT
I have a 1999 ford explorer sohc 4.0L v6 and Im replacing the front timing chain and the left cassette chain kit. I need to know how i can set the timing? I wanna buy a haynes repair guide but not sure if it has the info. I need. I will appreciate any help Thank you guys
Fun job...I just got done doing mine, except I did all the chains and tensioners....there are posts that are perfect for the job. The only thing I can add is that you will need to drop the oil pan and pickup...you are going to find debris there..And do yourself a favor get the otc toolkit...it makes doing the job easy and right
your welcome.
:salute:
Ok the chains are isntalled and the timing is good the motor rotates freely. So is just put everything back. I will add some pics later.
