nvrhapy
- October 29, 2003
- detroit, michigan
- 96 sport
ok i did some searching on here and this is what i found. "how to change tranny fluid" Before draining your tranny go to your local hardware store and get a piece of rubber hose about the diameter of your little finger (1/2 to 5/8th inch) and four (4) feet long. After draining the fluid and cleaning off the magnent at the end of the drain plug feed the piece of hose from the engine compartment down to the tranny filler plug. You will be able to push the hose about 3 inches into the body of the tranny. Connect the hose to a funnel or one of those adapters made for bottles that you can open and close. After filling the tranny with 2.5 quarts of the red stuff disconnect the hose from the adapter or funnel and blow through it (that way you avoid getting the engine coated with fluid.) Replace the filler plug, pull the hose and your done!
if there is anything i'm missing let me know, also where would i find the metal plugs to replace the rubber ones.
