CdnCory
- April 17, 2004
- B.C, Canada
- '93 2-door
*sorry for the long post*
Incase you are not up to speed with my problems, my other thread is here.
I did not have the money to buy the whole new set of wires, so what I did was strip the wires back, sprayed it with some 'battery maintenance' spray to get the corrosion off, crimped and soldered on some ring connectors, then coated all of the stripped wire with dielectric grease, heat shrinked it all together and bolted it all up to a wing bolt terminal (I didnt get around to running the alt-batt). Now, first thing I noticed was that my in dash voltage meter was very low (around the n on 'normal'). I tested it with a DMM and it read 12.5 (which is what it was before, but the indash meter was reading higher before). So I was driving home, and about 1/2 hour into the drive i noticed a dash light flickering on and off so I turned off my stereo and heater and driving lights. A few mins later the ABS light turns on. Then my tach stops working. Once I got into town, I turn off my headlights alltogether and everytime I had to stop, it nearly stalled everytime I accelerated. Now what I am wondering is if my alt finally died altogether (just by chance at the same time I fixed my wiring), or is it somehow related to my rewiring (even though I am SURE the connections are way better now)?
