snowburns
- December 7, 2002
- Anchorage, Alaska
- '96 XLT
Well I wanted more lighting, so I bought some cheap WalMart driving lights (21 bucks) my friend bought some too for olds cultass. We're both impressed with how bright they are. On the track in between the actual cross bars there are little arches that move around and you can tie stuff down with, I took these off and bought bolts that matched and just screwed them down...it works pretty good, I need to adjust where they point though. Last thing I need to do is get some kind of covering and cover the wires, I was thinking some of that heat shrink tubing...
Hokie did a much better job mounting his reverse lights, and I was going to do that on the front but I could get the screws out of the end caps on the rails so I had go with something else....
