Argentimage
- July 25, 2009
- MI
- 2005 Limited
I have a situation where the check charging system beeps on accelerations.
It started a while back on just very hard wot accel. Now its down to moderate highway entry ramp type accelerations.
Battery is 1 year old and checks fine.
Alternator checks fine with the diagnostic checker as well as how they say to check it - output at 2000rpm.
Belts - tensioner and belt were changed two years ago (squeals), and now they have been changed again, this time the idler was changed too.
It actually seems worse with the new belt, idler, and tensioner - all OE gates.
I took the belt off and spun the alternator, no end play, no rattling, free spins, water pump-fan hub, spins but then you are spinning a fluid inside too.
Power steering pulley has typical Ford pump end play, newer fluid, compressor spins w/o indicating a symptom.
We are at 125k miles...
Looking for things to test check to avoid continued random changing of increasingly expensive components...
