Check engine codes 1151 & 1152 | Ford Explorer Forums
snipe2
Mechanicsburg, PA
1999 Explorer Limited AWD
Check engine light came on today. Checked the ecm and the codes 1151 and 1152 showed up. Anyone know what they mean?
P1151 - Lack of HO2S : A HEGO sensor : See Possible Causes :
: -21 Switch, Sensor : indicating lean at the : for DTC P1130 :
: Indicates Lean : end of a test is :
: : trying to correct for :
: : an over-rich :
: : condition. The test :
: : fails when fuel :
: : control system no :
: : longer detects :
: : switching for a :
: : calibrated amount of :
: : time. :
: P1152 - Lack of HO2S : A HEGO sensor : See Possible Causes :
: -21 Switch, Sensor : indicating rich at the : for DTC P1130 :
: Indicates Rich : end of a test is :
: : an over-lean :
: : fails when the fuel :
from Dead Link Removed
So can I assume I need to replace the -21? (whatever that is).
Thanks
