Webster3
Mr. Ed
- October 8, 2002
- Atco, NJ
- '94 Sport
I'm currently at work but on my way here my check engine light came on and the engine started running rough. It seemed to be ok while at idle, but got rough as I gave it gas. There was a slight loss of power I think as well.
The check engine light came on, then went off for a few minutes and then came back on for the duration of the ride. When I got it here I shut it off and started it back up and I could hear nothing wrong at idle.
Keep in mind that it is about 11 degrees here in NJ and we just went through a huge snow storm.
Here's the big question: I am at work and I cannot find a volt-meter anywhere. I'm looking at this diagram at http://www.troublecodes.net/Ford/ and trying to see if I can just use the "testlight" method with just a wire and then read the codes when they blink the "check engine" light?
Or do I HAVE to use a test light?
I really want to figure this out before I have to drive it home... if its a part I can pick up I may be able to have someone drive me to a shop and then fix it here. Help!!
Thanks!!
Ed
Thanks!!
Ed
