bryankeith
- March 31, 2011
- Lake Country, British Columbia
- 1998 XLT 4L SOHC E 4x4
Hi Everyone
Check Engine Light On.
PO174
Problems is when I start my vehicle up [1998 Explorer xlt 4.0L SOHC] in the mornings with a/c and other controls off, it runs rough, idle varies up and down, almost to stall, hard to control with throttle peddle,
,after warms up for a few minutes is seems to idle nicely.
Now when I plug the car in for several hours in the morning (say 15 degrees celcius) before starting it....it starts and runs great. But who wants to plug their car in during colder summer months.
During cold start idling with a/c or any other themperature setting ON (I think) the a/c compressor cycles...clicks on and off at short intervals. This really plays hard on idle -kicks down then up. Now it seems the A/C is on all the time even when the vehicle is on defrost...still cycles. I thought the a/c only works when the a/c or a/c max is on.
I have looked through all the dozens of posts and feel I could be doing many tests...so just thought I would run it by you pros.....
Bought vehicle....a while back replaced filter was filled -very dirty....bought a scanner and got the code PO174... later up popped the check engine light...
Really need your help as I transport my son who has epilepsy and special needs coupled with my disability...it is important we have a good starting vehicle. Money has been tight so if I can fix it myself that would be cool.
Thanks for you help!!!!!!!
Bryan O
PO174
Bryan O
