stuartporter
- April 13, 2000
Hi
the check engine light has started coming on my 94 xlt, it will come after heavy acceleration usually,stay on for a little while and then go out, the garage pulled the codes and said it was the oxygen sensor, aparently, there are two on the truck, is this correct?
How easy is it to replace them yourself?
And am I likely to cause any damage to the engine if I don't replace them pronto? the garage said that it's only for the emissions! is that right?
I have also noticed some an occasional little bit of hesitaion on the engine when you put your foot down, is this likely to be related to the O2 sensors?
I'm getting about 18-19 mpg, which from reading the other posts seems reasonable,
Thanks in advance.
Thanks in advance.
