Check Engine Light ???? | Ford Explorer Forums
rockymntnhi
Pueblo, CO.
98' Sport
My Check Engine Light is turnin' on ... I have a 98' Sport SOHC . My Check engine light has turned twice in the last month . I have diconnected the battery both times and it turns off for a good 800mi. Ford told me the compuer is probably getting a reading of a mis- fire .. But why???? When it turns on it does't blink, but stays on constant... I'm hopin' it's a fouled plug or bad spark plug ,does that sound right??????? Pleaze HELP!
How many miles on it? The O2 sensors have a habit of going after about 50K. You can always have the codes read next time it happens for a definite answer.
I've got 52k .. How much are they to replace?? Can it be done at home ,w/o to many problems ...THNX for the help......
I won't give you an answer on how much these are but can tell you that you can replace these yourself. The only thing is that it might be a few different things that can cause your Check Engine light to come on. Better scan the computer first to make sure you're replacing the right part,
just me.
Thanks ,sounds like a plan.........
