Check Engine? | Ford Explorer Forums
Check Engine?
le33sw
1999 Explorer, 115k miles, 4.0 V6.
The plugs were replaced approx 4k miles ago. This afternoon, as I was driving the 'check engine' (yellow) light came on. I tried fastening anything that is loose - no joy. Also listened to the engine, if there is some sort of a vacuum leak - can't hear anything out of the ordinary.
Any ideas as to what could be the problem?
Thanks in advance.
PS. My idle is a bit high (above 1000rpm) - I have had this problem from the day I bought the vehicle - I put it down to a duff idle control valve. Am I doing any long term damage by using the car with highish idle?
The idle doesn't bother me near as much as the reason for it. If you have a vacuum leak...and you have a CEL...and you have high idle, I would suspect the code is for a lean condition and yes...you could damage the engine by driving it that way. If the PCM can't compensate enough for the vacuum leak, you could burn a piston or valve. I would pull the code and repair this as soon as possible.
Not stupid at all. PCM is Powertrain Control Module...aka ECM...aka engine computer
CEL is Check Engine Light
