clack, bang, pow! no reverse... | Ford Explorer Forums
lwrdrhvn
vista, ca
1999 xlt
was going to back out of my parking spot when i heard a little noise as if something got stuck and let loose...
now i have absolutely no reverse... i've looked at the posts about the reverse servo but i don't know....
could it possibly be just that? the o rings are done and need to get replaced? i'm hoping... will it hurt the car if i drive it? it drove like normal other than not having a reverse and now i have two neutrals :)
i do hear some swirling, wizzing, clunking, sound when i place in reverse though...
what are your thoughts.......
Is it a 4.0 or 5.0???
I'm thinking a problem with the low/reverse servo or band, simply because you say all the other ranges are okay. If it is the band or servo, you shouldn't have manual first either.
so if i were to check out the low/reverse servo or band myself (if even doable by a complete novice) i might have some luck? if not, will it hurt the car if i put in the new fluid and the gasket and everything? i know its a stupid question...
i saw the thread on the low reverse servo and it seems pretty doable... i just dont want to mess up anything else...
manual first? how would i test to see if that was gone? its an automatic 99 explorer 4.0 sohc... another dumb ? eh?
thanks for reading...
To check manual first, put the shifter into Low. Also, when in drive, you should be able to feel it going thru all the gears...
I just had a simmilar problem with my a4ld, couple clunks then no reverse, replaced by a light grinding sound and whirling sound. I shortly lost drive after reverse went and was concluded by a friend that the planetaries are probably blown up, soon to tell if that really is the problem.
Good luck, hopefully you have a simple problem. Im not too experienced with transmissions but id consider a clang bang pow a pretty bad thing...
lwrdrhvn,
Ford has a redesigned part for the low/reverse servo, but cannot remember what the part number is. Also check the valve body gasket as this is also famous for leaking on the 5R55E. I got the revised valve body gasket from Torrie at Ford Parts Network and it really made a difference. The Numbers for valve body are Valve Body Separator 1L5Z-7Z490-FA, and Valve Body Service Kit 3L5Z-7M203-JA.
