It really prompted me to check my OM-2012 Ford Explorer 2 Edition printing and I found the following:
LEATHER SEATS (IF EQUIPPED)
• Remove dust and loose dirt with a vacuum cleaner.
• Clean spills and stains as quickly as possible.
• For routine cleaning, wipe the surface with a soft, damp cloth. For
more thorough cleaning, wipe the surface with a mild soap and water
solution. In Canada, use Motorcraft Vinyl Cleaner (CXC-93). Dry the
area with a soft cloth.
• If the leather cannot be completely cleaned using a mild soap and
water solution, the leather may be cleaned using a commercially
available leather cleaning product designed for automotive interiors.
• To check for compatibility, first test any cleaner or stain remover on
an inconspicuous part of the leather.
• Do not use household cleaning products, alcohol solutions, solvents or
cleaners intended for rubber, vinyl and plastics, or oil/petroleum-based
leather conditioners. These products may cause premature wearing or
damage to the leather.
Also check out of curiosity OM-2013 Ford Explorer 1 Edition printing:
CLEANING LEATHER SEATS (IF EQUIPPED)
• For routine cleaning, wipe the surface with a soft, damp cloth. For more
thorough cleaning, wipe the surface with a mild soap and water solution.
In Canada, use Motorcraft Vinyl Cleaner . Dry the area with a soft cloth.
The only product mentioned is Motorcraft Vinyl Cleaner in Canada.
Hope this helps.
Bobby
